'Last Update' field missing in Probe Watch Window
I am using LabVIEW 2014. I cannot see the 'Last Update' field in Probe Watch Window. How can I make it 'visible'?
Thanks!
(3,767 Views)
Accepted by jsamuel4
Move the separator more to the right?
(3,762 Views)
This is where a screen shot of your probe watch window would be useful.  The most likely cause is you have your probe watch windo too small and/or you have the value column too large.
(3,738 Views)
Yes, moving the separator to the right worked. Thanks!
(3,725 Views)
