Last value from tunnel
Am I doing something wrong?
Message 1 of 8
(4,137 Views)
No.  Nothing is wrong.  Look at ALL the items in that array.
Message 2 of 8
(4,131 Views)
And is more....
Message 3 of 8
(4,110 Views)
Accepted by TomSAVU
As has been said, you need to resize the array container (or add a scrollbar) to see the last value. (container size != array size!)
As you can easily see, you get the last value. Agreed?
Message 4 of 8
(4,104 Views)
Seems I am tired ... thanks a lot!
Message 5 of 8
(4,097 Views)
Do you want the last element of the array ?
The code is doing exactly that.
There is a fifth element that repeats the first element of the array.
Message 6 of 8
(4,095 Views)
@TomSAVU wrote:
And is more....
Please explain in a complete sentence what you perceive is the problem. Details!!!
(and please (please!!!) don't attach a new VI with the same name as a completely different older VI attached earlier!!!)
Message 7 of 8
(4,094 Views)
Accepted by TomSAVU
Now it's clear, thanks a lot, I didn't see there are more than four elements in the array.
Message 8 of 8
(4,078 Views)
