Launch two VISA
Hi guys. Is it possible lauch two VISA in the same VI? I want to realize a state machine that follows this steps:
1- identification first instrument connected via USB
2- reset first instrument
3- setting some parameters in the instrument 1
4- calling the second instrument connected via COM
5- wait that the instrument 2 set a particular register at 1
6- once the instrument 2 has completed the step 5 the instrument 1 should start an acquisition
7- close both the instrument.
The question is: is it possible realize all this in 1 while cicle?
(3,402 Views)
Yes, you can.
(3,400 Views)
mmm well then I must have done some mess because yesterday seems that it didn't work. I'll try again.
Thank you
(3,395 Views)
If you post block diagram image and pop-up error, it could help us find out what is going on?
(3,384 Views)
Fixed 🙂 the problem was that I did Use default if unwired on the visa signal so I got error when I tried to take the control of the second instrument 🙂
(3,379 Views)
Glad to hear that 🙂
(3,377 Views)
