Laview 2012 CAN 9853
I'm trying to configure cRIO controller with modules in LV 2012 ( installed on Windows 7 64 bit). I successefuly add the controller (NI 9082) and different modules but I can't add the NI 9853 module. The controller is not connected to the system, i insert the C Series modules through new target and device popup, but the CAN module doesn't appear in the list. I have installed the NI-RIO driver and restart the system but the problem remain.
Any suggestions?
(2,538 Views)
Hello lukalex,
I'm Mario National Instruments, which version of RIO installed? Have you tried to install the NI-CAN driver? Below there is a link where you can download and install them:
http://joule.ni.com/nidu/cds/view/p/id/3152/lang/en
I await your response
Mario
(2,457 Views)
Hello Mario Thank you for your reply, I solved with driver reinstallation.
Alex
(2,450 Views)
