Results into array.
Hi, i have a little problem. I want to fill an array with results from a Flat Sequence Structure.
Sorry, i cant publicate the code, but here is a screenshot.
I hope someone can help.
(I'm absolutely begginer.)
(4,049 Views)
Accepted by topic author touchko
Hi touchko,
you should use following items:
- shift register to keep the array stored for several iterations
- InitArray function to initialize the array for desired size
- ReplaceArraySubset to put your values into the right position (index)
It's a pity you can't show your VI. The small part is not sufficient for providing more help than this...
(4,041 Views)
Thank you for the fast reply! 🙂
(4,031 Views)
Hi touchko,
I don't see any reason not to post that code in here. (When you try to get homework done your teacher should notice your helpers too. 🙂 )
You can put all your code into one loop.
I tried to optimize as much as possible, but several things are unclear to me. (Why do you generate 10 shuffled numbers, but only test the first 5 of them?)
(3,996 Views)
I just want to put the results in to an array. Everything else worked perfect. (And no, i dont want to put my code into an array.)
(3,987 Views)
Arrays are for data, not code. Can you explain what you mean with the above statement?
(3,982 Views)
Sorry, not array, i wanted to write loop.
(3,974 Views)
