LeCroy Connection
Hi.
I have downloaded the instrument drivers but when  from the block diagram, I go to Find Instrument Drivers and then I double click on lcwave (so i suppose that the drivers are installed properly) it shows me some VI example...the problem is that when I try to run these VIs in the VISA resource name the name of the LeCroy is not  shown. I have properly connected it with the ethernet connection.
Any tips?
Thank you
(3,130 Views)
Accepted by inuyasha84
(3,116 Views)
Mmm the problem was more "easy" ...simply the ethernet cable was broken. Smiley LOL now it works properly
Thank you for your help
(3,112 Views)
