Lecroy Wavesurfer 454
hello everibody.
i am new in labview and i am tryng to use the Lecroy Wavesurfer 454 with labview 8.6.
unluckly i am not able to use the example vi in the driver file.
i run the example finder for Wavesurferand, then run lecroy wave series acquire waveform.VI and correctly setted the tcpip instruction with TCPIP::192.168.219.53::INSTR and run the VI.
the error that i received is:
VISA:(Hex 0xBFFF0011) Insufficient location information or the device or resources is not present in the system
even if with the ping 192.168.219.53 command works correctly.
(5,897 Views)
(5,880 Views)
Accepted by topic author rouge_italy
Hello Rouge,
Alan from LeCroy Tech Support here...  The problem is that the VISA resource string you are using isn't correct.  For TCPIP communications with the WaveSurfer400 series, you need to install LeCroy's VICP Passport on the remote PC; this is listed as a required component for the driver.  You can download the passport from LeCroy's website here: http://www.lecroy.com/tm/Library/Software/LabView/VICP.asp?menuid=8.   When using the VICP passport, the VISA resource string to use is VICP::<ip address>.  Please let me know if you have any questions!
Best Regards,
Alan Blankman
Alan Blankman, Software Engineer
Teledyne LeCroy
800-425-2000
http://www.teledynelecroy.com
alan.blankman@teledyne.com
(5,872 Views)
(5,702 Views)
Hi Rouge,
Glad to hear you are up and running!  Note that the VICP Passport only needed to be installed on the remote PC.
Best Regards,
Alan
PS - for additional tech support, you can contact either me or the application engineer in Italy at applications.it@lecroy.com
Teledyne LeCroy
800-425-2000
(5,688 Views)
is there any LeCroy product that can't use Labview ?
(4,631 Views)
(4,619 Views)
