Led status
@ali9963 wrote:
can you please save to 2015.
I have attached vi please find this.
when i open my application now by default color of status buttons is green i want it to be yellow.
but when run the test it will validate the response and displays the led as green and red if the test is pass it displays green and when fail am displaying
Ali
Were we supposed to write the tests, too? Please don't attach VIs with almost literally no content. Especially on a phone, it's tricky to determine that you're looking at two indicators and a lot of white space...
GCentral
Message 11 of 19
(1,529 Views)
can anyone help with this Vi
Message 12 of 19
(1,524 Views)
Do you understand the methods for changing boolean colour? If so, please mark the appropriate solutions and then if you need help with the logic of your application, consider a new thread. Please try to be specific about what you're having problems with.
If not, please let us know what's not clear so that we can try to explain in more detail the setting of the boolean colours.
GCentral
Message 13 of 19
(1,521 Views)
@ali
your vi contained only to controls/indicators, for which you defined a type definition,
which you did not include. so there is not much we can help you with.
second there is absolutely NO logic inside, so we cannot help with that either 😞
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 14 of 19
(1,516 Views)
yes the status led is is an indicator.
Message 15 of 19
(1,513 Views)
so what?
Message 16 of 19
(1,510 Views)
@ali
you must have more than only the vi with the two indicators.
for example i know you must have the type definition, which defines your two indicators.
if you have more logic vis then post them too.
but all in all i would say, you really should start with the tutorials that are pinned on top of the labview disscussion forum.
regards
Message 17 of 19
(1,499 Views)
Here are the basics.  You will need to grow this to get what you want.Color Change.pngThe Desired Result Boolean within the loop is only to show that the Status color remains yellow until the test completes regardless of its state.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 18 of 19
(1,495 Views)
And backsaved to 2015 in anticipation of the request.
GCentral
Message 19 of 19
(1,490 Views)
