Lego Mindstorm
Has anyone seen or tried the Lego Mindstorm software based on Labview?
Is there any way to use Labview itself to program the unit? Thanks
John
Message 1 of 9
(5,862 Views)
I never used the software based on Labview ( Mindlab or Robolab I think
it's called) but I can say for definate that you can use the Lego unit
through LabView.
I don't no whether you can actually program it so to speak but you can run
programs on the unit and send direct commands to the robot (e.g Motor 1 On,
Read sensor 1 etc)
This can all be done through ActiveX in labview. The active x component
needed is spirit.ocx which is installed on your computer when you install
the Lego software that comes with the mindstorms set.
The SDK for spirit.ocx is available on the seb (sorry I can't remember the
address) and provides details of all the available methods and properties.
Hope that helps,
Andy.
ed on Labview?
> John
Message 2 of 9
(5,862 Views)
Hello
Yes off corse
In my opinion it ist better to programm the lego mindstorm 1.0 or 2.0 with labview. The origional software for mindstorm ist not the best i think.
cause its a software for children and younger people.
If i became the nxt, i programm it with the software that is in the box. But then i learned in a lab view camp to programm with labview.
lab view is also much better in thinks like complexity.
I am sorry for wirting and style but i am a from german.
good luck
(german)
viel spass
Message 3 of 9
(4,602 Views)
Hello
Yes off corse
good luck
(german)
viel spass
Message 4 of 9
(4,602 Views)
This article is intended to indicate the installation and configuration process between LabVIEW and educational robot Lego Mindstorms NXT wirelessly, this will enable LabVIEW developers in having a mobile platform for the development of projects and autonomous robots, we need to install some programs the computer:
https://decibel.ni.com/content/docs/DOC-32448
Message 5 of 9
(4,552 Views)
This article is intended to carry out a program to monitor the status and speed of a motor connected to the NXT Intelligent Brick MindStorm from the front panel on the computer
https://decibel.ni.com/content/docs/DOC-32450
Message 6 of 9
(4,551 Views)
This article aims to make a program that performs the reading of a sensor connected to the NXT Intelligent Brick MindStorm, display a message on the LCD screen of the device while on the front panel of our program:
https://decibel.ni.com/content/docs/DOC-32449
Message 7 of 9
(4,550 Views)
This article is intended to record the activity of the buttons on the NXT Intelligent Brick MindStorm, while pressing a particular button will produce a musical tone while a LED lights in the program.
https://decibel.ni.com/content/docs/DOC-32451
Message 8 of 9
(4,549 Views)
This article is intended to control the direction and speed of a Lego NXT robot using the directional buttons on the computer keyboard, strategic control distance limited by the scope of the Bluetooth transmitter installed.
https://decibel.ni.com/content/docs/DOC-32462
Message 9 of 9
(4,548 Views)
