Less than operator misbehave
The values came from (string to number) pattern match and were misbehaving.
After tinkering with type casting and formats (didn't spend much time though), there was no change in wrong evaluation:
Message Edited by labview-programmer on 06-04-2010 10:19 PM
Message Edited by labview-programmer on 06-04-2010 10:21 PM
Best,
Aniket
Message 1 of 9
(5,122 Views)
Accepted by labview-programmer
Sneaky. X is 4.4999999999999998
Richard
Message 2 of 9
(5,108 Views)
We have our weekly (at least) winner in the mysteries of floating point values contest.
See this thread to start.
http://forums.ni.com/ni/board/message?board.id=170&message.id=41383&query.id=2902191#M41383
Message 3 of 9
(5,106 Views)
And another nickel to my retirement fund!
Message 4 of 9
(5,098 Views)
Better re-check your statement. They are only depositing 4.99999999982 cents.
Richard
Message 5 of 9
(5,087 Views)
No it works. And this is common problem then working with floating point numbers :smileyvery-happy: The problem are caused by small rounding errors. The number format is the source of the trouble. It has been a lot of postings about this
Use the in range check instead.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 6 of 9
(5,075 Views)
Yes, correct.
but least expected this. as it was initialised as fig.1 and incremented as fig.2
Best,
Aniket
Message 7 of 9
(5,072 Views)
Hey, don't be stealing my salami! (wikipedia: Salami slicing)
Message 8 of 9
(5,071 Views)
labview-programmer wrote:
Yes, correct.
Aniket, change 'em to DBL's.
Richard
Message 9 of 9
(5,021 Views)
