Levenberg Marquardt, initial guess coefficient
HI there,
I want to use Levenberg Marquardt tool, in which there is one option of Initial Guess COefficeint for that i have 4 parameter for initial geuss that are frequency, amplitude, phase and constant. i have all this four parameters are ready in the form of individula numeric form, if i want to connect this to initial guess coefficient port then how can i do?
if some body have done this please guide me,
Thanx in advance
raj
(2,778 Views)
Wire the four numerics in the correct order to a "built array" node (resize it for four inputs). You'll end up with an array of four elements.
(2,763 Views)
