Libusb and Labview
I have a usb device which I I want to control via labview. I have a
Windows dll that uses the libusb library. That dll contains a function
that returns a device handle of type usb_dev_handle.
It is defined a:
struct usb_dev_handle;
I then want to use this handle as a input for other functions but of
course labview doesn't know about the usb_dev_handle structure. Is
there a way around this.
(6,169 Views)
assign it to U32. see page 2-25 of the lvexcode.pdf manual.
(6,162 Views)
Hi.
I have tried the same thing with labview and libusb and had the same problem, you had.
Do you have an answer to that problem of communicating with an libusb-device by calling the library-function in labview?
if you have a working solution could you please help me and send it to me?
That would be very nice.
Thanks ang good by.
(5,976 Views)
A great lengthy document concerning calling external code in LabVIEW can be found here.  It states the calling convention of how to handle different datatypes.
I hope this helps,
Nadim
Applications Engineering
(5,960 Views)
Nadim your link is broken
(3,140 Views)
It's here now:
https://www.ni.com/docs/en-US/bundle/370109b/resource/370109b.pdf
Also you're replying to a thread last posted to in 2007, it's not at all surprising.
(3,129 Views)
And the information about using an int32 for such a variable is wrong now. You should use a pointer sized integer to allow the program to work in LabVIEW 64-bit too.
Rolf Kalbermatter  My Blog
(3,103 Views)
