Limit the charecter length of cell in listbox
Dear Sir,
Please help me to implement the logic for limit the characters length of each cell in listbox.
Thanks & Regards,
S Nagaraju
Message 1 of 8
(4,287 Views)
Hi S,
pseudocode:
FOR EACH cell in listbox
   cell.string := StringSubset(datastring, 0, MAXLENGTH)
NEXT
 What have you tried so far?
Message 2 of 8
(4,285 Views)
Dear Sir,
I am reading data line by line from .txt file and displaying the lines in listbox. Plz find the enclosed VI & text file for more clarity.
The representation of listbox should be Emitter Name, Date & time.
S Nagaraju
Message 3 of 8
(4,271 Views)
Accepted by Sonti_11532
Hi Sonti,
that's no MultiColumn listbox, it's a simple listbox…
Just apply the logic presented above: limit string length for line in your text file BEFORE writing them into the property node of the listbox!
It just requires a FOR loop and a StringSubset function…
Message 4 of 8
(4,262 Views)
Thank you for the solution.
As you mentioned here i am able to display Enitter no, data & time.
But, based on selection I have to process entire data that means full line.
How to get the full data of line if i select one emitter from listbox?
S Nagaraju
Message 5 of 8
(4,242 Views)
Hi Sonti,
the listbox gives you the index of the selected line. Use that index for getting the element from your array of lines using IndexArray…
Message 6 of 8
(4,232 Views)
Dear Sir,
Thank you very much its going fine.
And i am able to remove the empty lines from listbox also.
S Nagaraju
Message 7 of 8
(4,176 Views)
Hi S,
it's a bit dangerous to read the Listbox value before you set the listbox elements…
And you don't need the "value" property node, just use the Listbox terminal!
Message 8 of 8
(4,156 Views)
