Limitations in the TDM file format?
Are there any limitations in the TDM file format or Write to measurement file Express VI ? Can Write to measurement file Express VI be used to write measurements of many hours or even days without problems?
As a side question, is there a way to define the TDM name. When I use Write to measurement file Express VI to save TDM files, DIAdem shows them as unnamed.
Tomi
Tomi Maila
(2,559 Views)
Hi Tomi,
TDM is not limited as I know, but a good site to have a look about TDM is here: www.ni.com/tdm
If I where you, I would use the Data Storage VI´s to save my data. You have quit more options for saving descriptions and informations in to your TDM-File.
You can find these VI´s in the File I/O Palette as a Sub-Palette.
I also attach you a Picture from the TDM-Seminar in Switzerland, this Picture explains the use of this VI´s.
Hope this helps,
Alex
NI Switzerland
Carpe DIAdem
(2,550 Views)
