Limited number of inputs due to connector pane
@govindsankar wrote:
I am doing a code where I replaced the global variable with an FGV. But the limitation here for me is I am limited to the connector pane inputs. Right now I am using 8 inputs, so I use 8 inputs of the connector pane. In the future if we added more inputs it will be not possible with the FGV. So what is the best way to overcome this problem.
Use Arrays or Clusters for to group your data, not seperate inputs.
=== Engineer Ambiguously ===
Message 21 of 23
(502 Views)
Unfortunately, most readers of this Forum, including some real Experts, have not mastered the skill of being able to read the code that Posters fail to post. If we cannot see "what you did wrong", we are unable to tell you how to fix it. (Bob Schor 28 August 2018)
What do you mean, I have uploaded the code?
Message 22 of 23
(483 Views)
That is his signature.  It gets applied to every message automatically.  It doesn't mean it specifically applies to you.
It's there because so many people write a message saying something is wrong with there VI and don't bother giving useful information or even attach a VI so we can see what might be wrong with their code.
Message 23 of 23
(468 Views)
