Line Coding RZ-NRZ
Hello.
I would like you to help me make Line Codes RZ-NRZ in labview.
Unipolar, Bipolar, Polar, Manchester, AMI
(7,682 Views)
Could you tell us a bit more about your application?  For instance what hardware are you using or just more information about the data and clock you are using?
For getting started, here is a forum post that discusses creating a Manchester encoder.  The second page of the post provides some example code.  This may be helpful in building the line encoders you are asking about.
http://forums.ni.com/t5/LabVIEW/how-can-i-build-a-manchester-coding-in-labview-signal-processing/td-...
(7,633 Views)
There is also an AMI VI at \examples\database\database example subvis. It's part of a T1 simulator.
(7,623 Views)
Thanks for your reply first, both of you.
I want you to help me make this one in labview
(7,619 Views)
Have you had a chance to try the examples mentioned above?  Also if you share specific problems you are having with the implementation, it would be easier to help.
(7,569 Views)
look there is a project that i have to make these lines in labview.. but i dont have any clue about labview so i want you to help me somehow to make these signlas in labview
if you can help me sending any file to open it with labview so i can check it would be useful !
(7,543 Views)
