xnet can:trasmit time
EN:xnet CAN I would like change runtyme "trasmit time" propreprty for active session "Frame Out Ququed". How can I do this ?
IT:Librerire xnet can: vorrei cambiare runtine la propietà "trasmit time" in una sessione "Frame Out Ququed". Come posso fare?
(2,247 Views)
I attached a screen shot with the property node you should use. "Transmit Time.jpg"
You must also configure the frame active, otherwhise, it does not work.
Have a nice day!
(2,172 Views)
