Linear Clustering Methods?
Are there any clustering methods well suited for detecting linear clusters of points? I'm working with an array of (X,Y) data that form several lines. I've attached a picture of an example dataset. I would like to identify each line, isolate the points associated with the line and do a linear fit to extract the slope. I've explored LV clutering tutorials, but every method I try isolates circular clusters of points. If clustering doesn't work, are there any other ways  to extract these data?
Chris
(3,264 Views)
Have you tried Gaussian Mixture Modeling?  It sounds like you have been using K-Means methods which tend to have trouble with high aspect ratio regions since they use simple distance assignments.  Usually you end up having to generate a large number of regions to get a decent result, and your lines wind up being covered with many circular subregions.  I am sure that there must be some methods in the statistics literature, just brush up on your hyperplanes before you start.
(3,232 Views)
