how to create alarm system on VI
Hai, i'm current doing an alarm system using LV 8.6. together i attach a simple VI. how can i make a simple alarm system so that when the measured RMS value exceed any number that user can define, a beep sound will apear
Message 1 of 9
(11,544 Views)
Hi hafizzuddin,
what about a simple comparison function (greater than) followed by a case structure with a beep function? As easy as it is!
Message Edited by GerdW on 02-04-2010 09:29 AM
Message 2 of 9
(11,535 Views)
hi GerdW, i'm not really familiar with beep.vi app. i tried to do a simple VI as u guide earlier but i dont know how to connect the beep.vi. can u show some tips on the vi i attach.
Message 3 of 9
(11,517 Views)
Hi hafizzuddin,
I don't have LV at hand, so can't look at your VI...
But after reading the help (as linked above) you have nothing to wire. Default setting is to use system alert beep and ignoring frequency and duration...
Have you read that help text?
Message Edited by GerdW on 02-04-2010 11:35 AM
Message 4 of 9
(11,505 Views)
Accepted by topic author hafizzuddin
Regards
Guru (CLA)
Message 5 of 9
(11,495 Views)
thank you all
Message 6 of 9
(11,487 Views)
Guru took this as an advantage and gained a solution count.... Smiley Wink
Message 7 of 9
(11,485 Views)
Hi Mathan,
oh yeah, with the upcoming "Forum Award" we have to keep an eye on such points Smiley Wink
Message 8 of 9
(11,483 Views)
Mathan and gerdW
hmmm... Sounds interesting......
I would say i was "free" (which means "relaxing") didnt had anything to do apart from looking at the forum!!!!
Anyhow everything counts 😉
Regards
Guru (CLA)
Message 9 of 9
(11,431 Views)
