Linear Frequency analysis SOUND EVENT SIGNAL
Hello guys,
I'm in a middle of sound evaluations and have some issues trying to perform a linear frequency analysis using Labview, I've been trying FFT analysis VI's but I'm unable to to recreate what I'm looking for. I'm acquiring the signal of certain noise usign a microphone, then I scale that signal to assign the correct units, afterwards i would like to perform such analysis.
Does anyone here has an idea on how to perform such analysis? Any help will be truly appreciated...
I'm attaching a sample picture of what I'm expecting to have after the analysis.
Thanks in advance
(3,151 Views)
An FFT is pretty straightforward with LabVIEW, what code are you using and how does the result differ from what you expect?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,136 Views)
Hi mikeporter,
I already solved my issue , thanks for your reply.
SergeArmz
(3,081 Views)
