cannot store data in spreadsheet file.
I have built this VI,It reads data from serial port and stores data in text file.But i want to log data in excel file directly.I ahve read other posts simililar  problem and implemented some solutions suggested but failed.Please help
Message 1 of 16
(5,144 Views)
Hi pardhimegha,
have tuto how to send and receive your data.
https://www.youtube.com/watch?v=VpxBTtvCklo
Patrick
Certified LabVIEW Developer
Message 2 of 16
(5,117 Views)
I have watched so many videos like this.
I dont have any problem regarding serial read or write... Problem is that i cant store data in spreadsheet file..
Message 3 of 16
(5,101 Views)
Hi, pardhimegha
I ran your VI and have nothing to recevie, so it cannot store anything.
Because you use same port to send and receive data, it cannot work.
One com port have TX and RX. And you must connect those pins or use other devices/com to send/receive data.
Patrick
Message 4 of 16
(5,083 Views)
are you sure....??
coz I ran that VI and and I have stored readings in text file..
 here is file of readings ...
Message 5 of 16
(5,071 Views)
Hi pardhimegha,
so what exactly is your problem?
At first you said you cannot store anything in your text file and now you show an example file with your device readings!?
- Your VI should do what you want it to do, but you should implement some error handling!
- Using BytesAtPort directly after VISAWrite will most often not yield in the answer of the command given by VISAWrite…
Message 6 of 16
(5,060 Views)
I have clearly stated that I want to store data in SPREADSHEET file..Which I am unable to do..
And my current VI stores data in TEXT file.
Message 7 of 16
(5,053 Views)
Accepted by topic author pardhimegha21
Hi pardhimegha,
rename your file from *.txt to *.csv and you're done…
Message 8 of 16
(5,048 Views)
You could right click on your file and choose Open With->Excel.  Excel will be able to open up that file without any problems.
Here is a little more effiicient version of your code.  It uses the termination charcter to stop the VISA Read instead of asking how many bytes are at the port.  It also opens the file once before the loop and closes it once at the end.  And finally, you really should close your port after the loop.
Is that VISA Write even needed?  If you are leaving the Write Buffer control empty, you can just get rid of it.
Message 9 of 16
(5,032 Views)
You are very confused about the difference between a spreadsheet file and an Excel file. A spreadsheet file IS a text file and has been pointed out, can be easily imported by Excel. To write a native Excel file, you must use ActiveX functions such as with the Report Generation Toolkit or the Write to Measurement File. In your case, I don't see the utility in getting that complicated when you don't need to.
Message 10 of 16
(5,023 Views)
