Link Menu Event and control event
I would like to have a menu item that performs the same function as a control event ("Save" or "Print"). Because there is only an event case for general "menu selection," it appears that I cannot just add an event for a specific case.
For example
Save Data case:
Button: Save Data
Menu Item: Save Data (Ctrl+S)
Print case:
Button: Print
Menu Item: Print (Ctrl+P)
Is there a way to do this without just duplicating the entire event case?
Message 1 of 9
(4,606 Views)
Create a user event that corresponds to the control. When the menu item is activated simply fire off the user event and pass and necessary data in the event itself.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 9
(4,602 Views)
Thank you!
I am unfamiliar with user events, so I will have to do some research on them.
Message 3 of 9
(4,589 Views)
Use Producer Consumer with Events template to start
In the consumer decode the event into a case structure by reading the menu item or menu tag string.
Heres a simple example
Message 4 of 9
(4,582 Views)
Thank you both. I have spent some time looking at the two methods, and I think I can make the second work. I'm still having a hard time understanding registered events, and how and what they cause to happen. It seems like an important concept, so I'll keep working at them. I've spent quite some time with the .vi provided in "help" for "Programmatically Fire Events." Is the "event structure" the same as the "event handler?" So it goes through the standard event case structure? If you have any ideas for clarifying this concept, I'd greatly appreciate it.
Message 5 of 9
(4,569 Views)
Yes, user events are processed in the event structure with the other standard LabVIEW events (value change, mouse up, menu eents, etc.). User events are very useful and are worth the time to learn.
Mark Yedinak
LabVIEW Champion
Message 6 of 9
(4,558 Views)
Accepted by topic author emc08
Hi emc08,
  You implement your requirement using a dynamic events(user defined events).I had attached a VI for your referece.
Thanks and regards,
srikrishnaNF
Srikrishna
Message 7 of 9
(4,550 Views)
Thank you very much for your help. I think I have a handle on these now.
Message 8 of 9
(4,523 Views)
Hi emc08,
  Then what about kudos?Smiley Sad
regards,
srikrishna
Srikrishna
Message 9 of 9
(4,511 Views)
