Link the "plot legend" checkboxes to individual booleans
Hi all,
I'm saving DAQ data from a waveform graph (where different channels are displayed as differently-colored plots on the same chart) and I want "unchecked" plots in the legend to go unsaved.
Ideally there would be some kind of boolean value associated with each checkbox which I could then use to say "yes, record" or "no, don't record."
Is there any way to do this? Or is there a better solution than this?
(4,300 Views)
Accepted by topic author AlecSt
I presume you are referring to the "Plot Visibility Checkboxes." You can use two property nodes for the graph: Active Plot and Plot Visible. Together those should get you the information you want.
Lynn
(4,288 Views)
I don't think those property nodes give the results I want -- those refer to the visibility of the checkboxes as a group. What I'm looking for is the boolean value associated with each checkbox.
(4,240 Views)
It works for me. I am using LV 2014. I happened to have a VI with a graph with the checkboxes used so I added the property nodes as a test. The values in the boolean array follow the visibility checkboxes checked exactly.
Note: The array of clusters wired to the autoindexing tunnel is the data going to the graph. This tells the for loop how many plots exist.
Lynn
(4,232 Views)
Thanks, Lynn. I came back to tell you that I was mistaking and that I got it working, but your additional answer clarified things still futher.
(4,223 Views)
