Linking VI and a Sub VI
Hi Pnt,
I do it but my Sub VI is in a  "While Loop" so every time it take the fearst value of this array nevertheless I put this array out of the "While loop"
Message 11 of 20
(1,189 Views)
Hi Basile21,
do you want to delete the graph only ones? You can use a "Actine Engine Structure" (global funcional variable) for it. Make one case in which you delete your graph and another one in which you can add new values.
Hope it helps.
Mike
Message 12 of 20
(1,185 Views)
Hi Mike ,
Iwant to delete the graph at every run of the VI, can you give me an exemple haw can I use the Global functional variable please.
Message 13 of 20
(1,182 Views)
Hi Basile21,
here is an example.
Hope it helps.
Mike
Message 14 of 20
(1,180 Views)
Hi basile21,
                     You can use an invoke node.Please check the attachment.
Message 16 of 20
(1,172 Views)
Thanks Mike I found the solution
Message 17 of 20
(1,149 Views)
Thanks Pnt I found the solution
Message 18 of 20
(1,148 Views)
Thanks Muks I found the solution
Message 19 of 20
(1,147 Views)
Happy to help. You can also say thanx everyone in a single msgSmiley Very Happy
Message 20 of 20
(1,144 Views)
