07-28-2008 02:05 AM
Hi Pnt,
I do it but my Sub VI is in a "While Loop" so every time it take the fearst value of this array nevertheless I put this array out of the "While loop"
07-28-2008 02:11 AM
Hi Basile21,
do you want to delete the graph only ones? You can use a "Actine Engine Structure" (global funcional variable) for it. Make one case in which you delete your graph and another one in which you can add new values.
Hope it helps.
Mike
07-28-2008 02:21 AM
Hi Mike ,
Iwant to delete the graph at every run of the VI, can you give me an exemple haw can I use the Global functional variable please.
07-28-2008 02:25 AM
Hi Basile21,
here is an example.
Hope it helps.
Mike
07-28-2008 02:31 AM
07-28-2008 02:47 AM
07-28-2008 04:29 AM
07-28-2008 04:30 AM
07-28-2008 04:31 AM
07-28-2008 04:33 AM
