Linux RTE Install
I feel like this is the best thread for this question.  But I could be wrong.
I was installing LabVIEW 2011 SP1 RTE onto our Linux server.  The RTE itself installed successfully. However, I got an error saying the Web Browser plug-in did not successfully install.  What kind of issues should I expect from this?  Just the inability to use NI Web Browser?
(3,868 Views)
The Web Browser Plug-In is needed only if you want your browser to display VIs that are embedded in Web pages (remote front panels).
If you do not need that functionality then you are good to go.
Rachel P. | Applications Engineer | National Instruments
(3,827 Views)
