NXT LabVIEW Maze program from Tufts will not run on EV3
I created the Maze program from Tufts that is found under Educator resources included with the LabVIEW software package (2012).  I'm running an EV3 with LabVIEW.  It seems be constantly executing the initializing function.  Attached is the vi.
Any help would be greatly appreciated.
Tony
(2,961 Views)
Hello Tony10,
I believe that the shift register is not wired; the input of the case structure is wired to a tunnel instead to the shift register. By changing it, you should be able to execute as intended.
Luis C.
(2,928 Views)
