Linux Shared Library
In order to create a LabVIEW application on linux without an X display, I complied the LabVIEW VI using the Linux Shared Library. I did this by right clicking on Build Specification and selecting New >> Shared Library, and in the Advanced section, checking the box labeled Use embedded version of run-time engine. At the end of the build process, a message came up informing that the build was unsuccessful, with the following message:
    "Error 1 occurred at System Exec: /usr/local/lib/liblbrdark.so8.5: could not read symbols: File in wrong format
     collect2: ID returned 1 exit status
     Possible reason(s):
     LabVIEW: An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @
     NI-488: Command requires GPIB Controller to be Controller-In-Charge."
I'm using version 8.5 on CentOS. I had no problem building it as an application in the normal fashion, so am confused about what the problem is.
(2,726 Views)
Hi Julian!
If you haven't looked through this documentation, this might help solve your issue.  If it doesn't let us know and we can certainly take the next steps to getting this figured out for you!
Running a LabVIEW application on Linux without an X Display
http://digital.ni.com/public.nsf/allkb/5D6EC36DCF43343786257449006919E6?OpenDocument
(2,708 Views)
