List in write buffer?
Okay i will search for ping! Yes i am sending *IDN, is that the problem?
Message 21 of 24
(883 Views)
No, it's not the problem if all of the instruments support the command. The command is a GPIB standard. The vxi-11 and lxi protocols are what vendors use to provide the same basic functionality of gpib.
Message 22 of 24
(875 Views)
Okay now i use VISA Writwe/Read should i use GPIB Writwe/Read instead?
Message 23 of 24
(871 Views)
Of course not. The point I was making was the command set/features of a compliant Ethernet instrument is essentially the same as the vendor's gpib version. With VISA, you don't really care as the exact same code is used for both.
Message 24 of 24
(869 Views)
