Listening to a port
I am wondering if there is a way to use Labview to listen to the communications
on a port and log the communications to a file. The idea is this, I have an ISA
board that is communicated to by a DOS program. I would like to "eavesdrop" on
the communications and log them to a file while the DOS program is running
(labview running in the backround if possable). Is there a way to do this with
Labview or any other program ??
Henry
(2,646 Views)
In article <3910BA3D.4085FB7F@loxinfo.co.th>,
communications
have an ISA
--- snippel
I don't know an easy way within LabVIEW, but there are nice programs
available from www.sysinternal.com They allow you to listen at ports,
files, regestry aso.
Hope that helps
Peter
Sent via Deja.com http://www.deja.com/
Before you buy.
(2,646 Views)
