Live plot from HP4193A
I would like to build a plot display for an HP4193A Vector Impedance meter.
This instrument is 1970's vintage and has analog outputs for a two pen plotter. It also has HPIB but no plot function so the data must be extracted by sending a frequency and asking for the magnitude and phase, or reading the settings and data as the instrument scans.
I have done this with Prologix and EZGPIB but it is painful.
Can Labview be installed in a Win10 laptop, or better still a RaspberryPi, and run as a standalone display?
Is there a hobby version of Labview that is affordable, less than $300?
(1,118 Views)
LabVIEW Community Download is free for non-commercial and non-academic use.
https://tmesystems.net/
(1,114 Views)
You could look at something like this...
https://github.com/jshorstman/Analog-XY-Plotter-Output-to-HPGL-Translator
Craig
(1,085 Views)
I don't see a reason that you can't wire the analog outputs to an AI channel source (either on a pi or through a USB 6008) and save a bunch of 70s Era HPIB headaches.
(1,039 Views)
Thanks for the replies.
I am going with Python and Pyvisa but there is a learning curve ahead.
(987 Views)
