Load Image Data Directly Into a PictureBox
Hello all,
I'm working on a help window, and I want to be able to store the help contents as image data (flattened to string) in a database. I want to then unflatten and convert it back to image data and load it into a PictureBox. Is there a way I can do that without saving the image to file? Currently, the only way I see to load an image to a PictureBox is by loading a saved image.
Redhawk
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
Message 1 of 11
(8,681 Views)
It's not clear exactly what you want.  Maybe this will work for you:
Run this code:
pb1.png   Then right-click on the "image data" terminal and select: Create -> Constant.
Use that constant in this code:
And to retrieve the image from the DB
Message 2 of 11
(8,643 Views)
Thought I explained it pretty well but I'll try again. What I want is for 'image data' to be loaded into a .NET PictureBox control directly instead of needing a saved image file. See the attached screenshot. Ignore all the math, it's to make the window look nice no matter what size the image is.
Spoiler
Redhawk
Message 3 of 11
(8,618 Views)
Why not just use a LabVIEW picture indicator?
Message 4 of 11
(8,603 Views)
I guess it's mostly that gray bevel on the outside of it that I don't like, but I might end up doing that.
Redhawk
Message 5 of 11
(8,598 Views)
If you use the classic version of the Picture control, you can color the border transparent.
Message 6 of 11
(8,593 Views)
To me the classic and regular version are both basically the same thing. Do you color it with property nodes or?
EDIT: figured out it's colored by using the paint tool in edit mode, just gotta get the cursor right on the 3 pixels of the border. Thanks!
Redhawk
Message 7 of 11
(8,587 Views)
Note: Those bezels on the classic controls can only be colored with the coloring tool.  There is no property available to access the color of a bezel.
Message 8 of 11
(8,580 Views)
Accepted by FireFist-Redhawk
I posted some code here that demonstrates a few things with the picture box.
https://forums.ni.com/t5/LabVIEW/Read-multi-image-tiff/m-p/3580103#M1002365
Here it loads an image, preserving the alpha layer information if there is any, it can select an image to display if a file contains multiple images, and does automatic scaling to the pane without additional code.  I used a similar set of code to allow for rotating of an image using .Net.
https://forums.ni.com/t5/LabVIEW/How-to-rotate-objects-or-pictures-on-my-FP/m-p/3200578#M927937
Message 9 of 11
(8,500 Views)
The attached may be of use with some modifications for PNG instead of JPEG. It uses .Net.
Message 10 of 11
(8,381 Views)
