Load data from word in same shape of format
Hi all
I want to load data from Microsoft word into labview
but keep same format and template ,
attach word template file
how I can do that in labview
thanks
wisam
Message 1 of 12
(3,740 Views)
That's not clear to me at all.
Data? What data? The text, the table the images, all, any?
@Elyan_wisam wrote:
 into labview
During run time? Or while editing? What should it be in LabVIEW? A Word ActiveX container? Or an image? What do you want to do with it?
What do you expect? That LabVIEW uses Word as a template? Or that you can edit the Word "template" in LabVIEW?
That's really a Word document. Guess it's being used as a template somehow?
That depends on what it is you want exactly. Please explain.
Message 2 of 12
(3,717 Views)
Hi
what I want to do take all what in word document and present it in labview
by keep same  image , data and tables
Message 3 of 12
(3,710 Views)
Not sure why you'd want to open a Word doc in Labview ?
However if it is simply to display a page or two of information then you could capture the doc pages as jpgs and display those fairly simply within Labview.
Message 4 of 12
(3,702 Views)
@Elyan_wisam wrote:
Hi
So make a screen shot with snipping tool, and paste the image on your FP. it will look exactly the same.
Message 5 of 12
(3,690 Views)
Accepted by topic author Elyan_wisam
There exits a .NET Rich Text Control
If you spawn one on the Frontpanel, you can copy&paste the word documents content via  strg+a, strg+c and strg+v
I suppose, this can be done programmatically, if the word document was saved as a .rtf
most of the formatting will be preserved:
Alex
@NeilR
Message 6 of 12
(3,683 Views)
@alexderjuengere wrote: suppose, this can be done programmatically, if the word document was saved as a .rtf
Message 7 of 12
(3,680 Views)
Thanks you very much
Message 8 of 12
(3,648 Views)
Hi
Is there a way not  to clear the RichTextBox  when press on stop button
since now when I press on stop button  the vi stop and the  RichTextBox cleared
Wisam
Message 9 of 12
(3,627 Views)
And that's just one reason why the .NET "solution" is usually not really a solution. It's a quick fix, that usually causes more problems that it solves. But feel free to experiment.
As soon as the VI stops, the .net object is disposed. Nothing you can do about that. You can 1) not stop your VI (use it in a larger architecture) or 2) accept that it's disposed.
Message 10 of 12
(3,611 Views)
