Load different .Net DLL
I have a set of .NET DLL that have differen revision.  I want my labview code to select the correct set of .NET DLL to lead during run time.  is that possible?
Kudos and Accepted as Solution are welcome!
(2,751 Views)
Accepted by jyang72211
Hi jyang72211,
To make sure that a LabVIEW project refers to a specific version of a .NET Assembly, you will need create a .NET configuration file. This article has an example of a .NET configuration file.
Jordan G.
LabVIEW Product Marketing Engineer
(2,700 Views)
