Loading a VI into server memeory
Hi mwmwbers
AM try to buplish a VI on my local machine but the browser keeps give this error of "Requested VI is not loaded into the Server co0mputer"
I have enbled all the recommended server configurations and saved the  VI in the Labview www folder
What could be the problem and possible solution.
(3,192 Views)
please see the following KB for more information about this error:
Requested VI is Not Loaded into Memory on the Server Computer
Tobias
(3,178 Views)
Accepted by topic author Ambrose
Yah that worked.
Thnanks and regards.
(3,173 Views)
You should mark Tobias' answer as the solution - not your thank you. You can change what you did by clicking on 'Options' above the message body.
(3,158 Views)
