labview with OPC
hello,
             i am doing project with Labview with opc server. opc collecting data from the PLC, and all are analog inputs. i am doing dataloging on labview using data socket with OPC server. for the configuration setup i need a opc address for each tags from the server, for that i am using brows opc items.vi, its getting only each tags one by one, but i have 25 tags.
how to read the all opc tags by single task....?
please find the attachment
Balaji DP
(2,637 Views)
Dear Balaji,
thank you very much for your post on our webforum. It sounds like you need the Data logging and Supervisory Control ( DSC ) module. With DSC you are not using datasocket but shared variables.
Please find the following VI with the DSC help file.
Martijn S
NI Netherlands
(2,613 Views)
