Loading a hex file into pic microcontroller using labview
LabVIEW runs on processors 32-64 bit microcontroller works on 8 -16 bits, instructions and memory management is different, maybe if your target hardware is 32-bit can make this work but needs to work on a bootloader for the device
Message 11 of 11
(738 Views)
