Loading string from DLL using Code Library Function node
I am experimenting now with Code Library Function Node element... what i wanted to do is, for example i compiled one .DLL file..which has some function which returns pointer to string... function looks like:
/* This function returns pointer to the character string */
char *pchar(int n)
     char *str[] = {"error", "String1", "String2", "String3"};
    return ((n != 1) && (n != 2) && (n != 3)) ? str[0] : str[n];
but when i load it in LabView from DLL, a string element on front panel displays trash... any ideas why?
p.s. when i do same with integer values... say my function is like int x = 5; return x; and then i load it in LabView to the numeric indicator...it works just fine!
so any ideas?
thanx
(3,892 Views)
Dear cyrax,
LabVIEW provides support for passing and returning the following string data types with the Call Library Function Node:
C String Pointer - a string followed by a null character
Pascal String Pointer - a string preceded by a length byte
String Handle - a pointer to a pointer to four bytes for length information, followed by string data
String Handle Pointer - a pointer to an array of string handles
Are you using the right string format in the CLFN for this specific DLL?
Also check out this resource:
Using a Call Library Function Node to Call a DLL Function that Returns a String that Includes Null Characters
http://digital.ni.com/public.nsf/allkb/FFFF8C757C41CB6486256EB3004C8D76?OpenDocument
and let me know if you are still having problems. Have a good one!
Best Regards,
~Nate
(3,872 Views)
Accepted by cyrax
char *pchar(int n)
so any ideas?
thanx
You can't return a pointer to data residing on the stack. At the time the function returns, the stack is reset to the state before the call to the function and in a multithreading environment like LabVIEW most likely long reused for other things when LabVIEW gets around to actually copy the data from the returned pointer.
Since this is a read only variable you could create a permanent memory storage for the strings by declaring your variable as static. This will create a globally allocated memory area for the string data (and also cause a compiler error when you try to write to that area somewhere in your code, which is a good thing).
Message Edited by rolfk on 01-11-2010 09:06 AM
Rolf Kalbermatter  My Blog
(3,842 Views)
