Local Variable or Write VISA Icon?
Suppose that you have a control in front panel to set amplitude of generator. If you do a loop in which you desire to increse every loop the amplitude it's better use a local variable of control in front panel or Icon WRITE of VISA to do this? What is the better solution?
Message Edited by Michelle1892773 on 02-23-2010 04:47 PM
(3,356 Views)
Accepted by Michelle1892773
Writing to the local variable in your code will do absolutely nothing in setting the instrument.
(3,353 Views)
