Local Variables Fun
Assuming more then one local for each variabe, how can I Locate local variabels in my VI?
I mean in the "sense" of "Find Terminal" just by a specific local.
Tnx
Message 1 of 11
(5,727 Views)
Accepted by NivShapira
Right-click on your terminal.  Find->Local Variables.  The search dialog should show up so you can go through them all (assuming there is more than 1).
Message 2 of 11
(5,725 Views)
Tnx
OK, you asked for it.....(I hope you are "refactoring" somebody elses code...... if not what Block Diagram is so large that you cannot easilly find local variables?!  I can smell code stench from here!)
From the FP press Crtl+A then Delete.
Press the broken run arrow.... all the unlinked locals will be in the list of errors.
Ctrl +Z will return you to your previous bad code.
Message 3 of 11
(5,713 Views)
I knew somebody was going to go there.  I should have known it was going to be Jeff.  I was feeling nice or I would have made a similar comment.
Message 4 of 11
(5,707 Views)
Tnx, you where both helpfull.
Hope to have less smelly code next time Smiley Happy
Message 5 of 11
(5,701 Views)
Really, it was in a century long past but, you should have seen my first vi's BD!  We all get better with experience
Spoiler
I hate to say it but, I ACTUALLY DID tell my boss "If you want me to use LabVIEW, I'll need a bigger monitor"Smiley Embarassed
Message 6 of 11
(5,696 Views)
Jeff,
Did you get the bigger monitor?
When LV first introduced color (LV2 or 3), I opted for a larger black and white monitor over a smaller color monitor.  I think I had a "page display" size.
Lynn
Message 7 of 11
(5,662 Views)
Hmmmm 😄
Message 8 of 11
(5,654 Views)
@johnsold wrote:
Jeff,
Lynn
Of Course I did!  Me and the guy over the cube wall both got great big CRTs so we could work efficiently.  Would you believe that "guy over the cube wall" has also joined an elite group I belong to?
LabVIEW programmers can learn---eventually
Message 9 of 11
(5,644 Views)
Jeff·Þ·Bohrer wrote:Of Course I did!  Me and the guy over the cube wall both got great big CRTs so we could work efficiently.  Would you believe that "guy over the cube wall" has also joined an elite group I belong to?
No, you never mentioned Mark.
Spoiler
I was about to to you crap about CLD not being that elite of a group, but I decided to stop myself
Message 10 of 11
(5,639 Views)
