Local Variables in State machines
I have been reading the posts that came up when I searched for the subject topic. Well let me thank Tbob and Shan for thier excellent samples  of using  of  clustered locals for data handling inside of a State machine.
Having started with LabVIEW two years back I  now have  commissioned four major  projects  where  the  SM architecture is used for machine control and  Loacl variables are used  for  data  handling between cases.
Today I am happy that  there  is  an elegant alternative  as suggested  with Local clusters and a single SR.  Good. But what about the projects already commissioned ? To decide whether to recode them, I need to know this :
- Each SM uses something like 150 to 200 local variables (Please don't laugh!)
- Taking the case of one particular indicator called "R.ANGLE" it has  in a total of  9 local variables in various SM cases.
Question is :
When I run the SM, does LV create  copies in memory  for 9  numbers of  R.ANGLE  indicators or  a copy for  only the variable that is currently being updated in a SM case ?  And discard it when I jump to the next  case ?
( The above SM is inside of a 50ms timed loop and till date running with no problems - atleast memory related )
Thanks for any insight.
Raghunathan
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
(3,481 Views)
Since LV does not know which copies of a local may need to be read some time in the future, the new value is written to ALL of the copies of the local.
So if you write to a idicator and thera are 9 local copies of that indicator, then the data is also written to the 9 "read local"s.
I hope I upderstood your Q.
Ben
(3,470 Views)
Hello Ben,
Yes you understood my query very well.
If that is the case, then I think I have created quite a lousy code ? Assuming that there are about 150 local variables and 5 instances of each, then when I launch the application, automatically 5 x  150 = 750 copies are loaded in memory ?? Sounds very depressing  if you ask me.
And I also suppose that the 750  copies remain in memory till the application is closed.
Kindly confirm if my understanding is correct.
Raghunathan
Message Edited by Raghunathan on 04-14-2006 10:56 AM
Raghunathan
(3,458 Views)
You are correct.
Ben
(3,449 Views)
Now, after Bens answers, if you start to rewrite your code ....
If you use one SR (I prefer at least two, I like to keep the error cluster separate)  another helping hint:
Use a type definition for your cluster, so in best case, you will only need to edit every subvi once.
Message Edited by Henrik Volkers on 04-18-2006 10:22 AM
Greetings from Germany
Henrik
LV since v3.1
(3,412 Views)
Hello Henrik,
That was a valid point about  segregating the clusters and using a type definition. It will defenitley help in code maintainability.
Thanks for  your kind tips and greetings from India.
Raghunathan
Raghunathan
(3,399 Views)
