Local maxima and minima from acquired signal evaluation
i have to create a VI that beginning from an input signal evaluate local maxima and minima.How can i do?
Thank you so much for your help
(3,315 Views)
Accepted by johndoe2125
If I give you two numbers, how can you find the maximum and minimum?  What if I gave you one more number after that?  And how about another number after those three?  And so on.
Think it through.  If you can't do this "in your head", go Old Fashioned and take a pencil, a piece of paper, and try with two numbers.  Now add a third, a fourth, and so on.  Do you see a pattern?  Can you make a "rule" that might correspond to things you know about Programming Languages, or about LabVIEW?
(3,292 Views)
I haven't understand yet. Can you send me a possible solution?
(3,291 Views)
Then why did you marked the post as solved? It will not get more views then.
Kindly start with basics of LabVIEW and try to write your VI on your own and then post if you get any errors. We will guide you from that point.
Mathan
(3,225 Views)
