Log DigitalOut and AnalogIn in one waveform
Isn't there any solution for this problem?
I still couldn't find a good way. Even tried to reduce acquisition rate. But I couldn't get a reliable data synchronity.
Yves
Message 11 of 13
(628 Views)
Yves
I suggested you use an Action Engine in an earlier post but checking your code shows no sign of you attempting to try an Action Engine.
Maybe you don't understand this forum and are waiting for us to write your code. Speaking for myself, my boss would fire me if he caught me writing code for someone that was not paying (he own my intelectual property). So all I can do is encourage you to try an Action Engine.
Doing waht I can without getting fired,
Ben
Message 12 of 13
(605 Views)
Ben
Of course, I didn't meant to have this work done by other people.
I read studied your Nugget several times, but I'm not sure if I fully understood it. (isn't there any printscreen of the "pump_AE" mentioned in your nugget?)
I have changed some piece of the code.  I'm still confused if I can put the whole data acquisition in an AE. I suppose that it is possible because it looks like you did this in the pump_AE.
Yves
Message 13 of 13
(589 Views)
