Logarithmic Ramp pattern by Delta
Hello everyone ,
is any one know the formula of Ramp pattern by delta but in logarithmic type or log spaced vactor between Start value and stop value?
Thanks in advance. your help is highly appreciated
Kuddo welcomed
CLAD-CTD
(7,156 Views)
Hi Gab,
any one know the formula of Ramp pattern by delta … between Start value and stop value?
step := start
REPEAT
  step += step + delta
UNTIL step >= stop
What is a vactor?
And which values do you expect for a "logarithmic type" - when you still want to apply a "delta"?
(7,151 Views)
What is a vactor?
sorry for misspell. Here vector mean Array with value will be in logarithmic scale.
For example if my start point  =1 and stop point =10 and delta =1,
then in linear type i am expecting  Vector ={1,2,3,4,5,6,7,8,9,10}  (end point included).
Similar for logarithmic Scale, i am expecting  Vector be like ={1,1.29,1.66,2.15,2.78,3.59,4.64,5.99,7.74,10} .
Gab
Kuddo welcomed
CLAD-CTD
(7,132 Views)
Hi Gab,
How are you calculating these values?
I would try this (as long as you cannot provide anymore details on your values):
Edit: Found the solution by counting more accurately:
Why do you ask for a formula when you already can calculate that vector?
(7,125 Views)
Accepted by topic author Gab008
@GerdW wrote:
Hi Gab,
I did similar like you. see attached VI.
Why you divide all array element by 10?
I asked for formula because in the help of "Ramp pattern.vi". there is formula for linear and logarithmic type, ramp pattern by Sample. but i am unable to find formula for ramp pattern by delta in logarithmic type. so to make sure that whatever, i am calculating is theoretically correct also.
Kuddo welcomed
CLAD-CTD
(7,121 Views)
Hi Gab,
That answer is simple: the "Delta" instance of the Ramp function does NOT support logarithmic type. So there only is a formula for linear ramps given in the help…
I would go this way:
With logarithmic scales you most often want either some certain values (like 1, 2, 5, 10) or "evenly spaced" on the logarithmic scale - as calculated by the Ramp function in "Samples" mode…
But thanks, now I learned about the "logarithmic" feature of the Ramp function. Never needed that before!
(7,109 Views)
