Logging data with time stamp in file adds a null line
I can't figure out why I am getting a 'null' row in between every row of data when I use the timestamp in my data log. If I remove the time stamp the 'null' line goes away and attaches. I have attached the image of my VI as well as the spreadsheet output that shows the null line between each row. I also attached a copy of my VI
(735 Views)
Accepted by dmeissner
Add a "Trim Whitespace.vi" after the "Array to Spreadsheet String.vi"
Ben64
(724 Views)
It is not the timestamp, it is the Array to Spreadsheet String. That node appends a newline at the end of the string.Write Delimited Spreadsheet uses the same function, so you end up with two newlines after another.
Use Number to Fractional String instead.
(718 Views)
Thank you!
(703 Views)
