Look for a filename containing a Wildcard (how to?)
My program enters a loop, and when a certain file is found, the loop exits and resumes duties. The file will start with "Pos_" or "Neg_" or "Warn_" then have some arbitrary junk, before suffixing in txt. So... how do I search for a filename with a wildcard? The attached JPG is how I'd like to do it, (and this works fine if the filenames are constant) but of course it doesn't work for the wildcard.
Richard
(3,120 Views)
List the files using the list function. The list function accepts a path with wildcards. If you need to filter the file list further wire the file list to a while loop, and search the file name array for either of the name headers you want...
(3,120 Views)
Thanks for the response Mads. I'll give that I try. I'm horrible at arrays, I tend to keep everything flat. Probably stoopid in this case.
Richard
(3,120 Views)
