Looking for Agilent/Keysight/HP 6634B LabVIEW Drivers
Hello everyone,
I have tried seraching everywhere but I can't find the labview drivers for the  Agilent/Keysight/HP 6634B power supply. The only ones I can find are for the 6xxxA series, but not the 6xxxB series.
If anyone has them or knows where to find them I would be very grateful!
Message 1 of 10
(7,022 Views)
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E947E659CE034080020E748...
Or you can create your own driver using the SCPI command list which you can find in the manual...
Message 2 of 10
(7,019 Views)
Thanks for replying.
These aren't the LabVIEW drivers. These are just just some automated update software!
Message 3 of 10
(7,016 Views)
Accepted by quantisedpenguin
You are in a mistake. That is indeed the LabVIEW driver, IVI class type. If you do not like that this driver calls DLLs, as I wrote above, you could just create your own driver pack following the SCPI information located in the manual of your device...
If you want to use the available driver, follow these steps:
  1. Download and install IVI package for your LV version: http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/n8:3,ssnav:ndr/sb/-nigenso4-...
  2. Restart PC
  3. Install the IVI driver from this site: http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E947E659CE034080020E748... (direct link for the exe: http://sine.ni.com/apps/utf8/niet_download_id.log_ids?p_profile_id=1270941&p_doc_id=E3B19B3E947E659C... )
  4. Enjoy:
Message 4 of 10
(7,008 Views)
Oh wow, I didn't see this when I first tried installing that package. This is great, thank you!!
Message 5 of 10
(7,000 Views)
No problem, good luck with your project! 🙂
Message 6 of 10
(6,997 Views)
What about HP6632A? Where can I find Labview drivers for it? I'm using Labview 14.0.
Thank you.
Message 7 of 10
(6,706 Views)
Thank you.
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=014E5475A4556F51E0440003BA7CCD...
Message 8 of 10
(6,704 Views)
Thanks, Blokk. I also found it. I found this page useful too:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3XpCAI&l=en-US
Best regards.
Spring.
Message 9 of 10
(6,694 Views)
Screenshot (136).pngI tried installing the drivers but it seems there are a lot of errors popping up. It seems one of the get_error_info files is missing from the driver pack. I have attached a screenshot of the errors. If someone can help me out it would be of great help.
Thank You
Message 10 of 10
(1,074 Views)
