Loop Block
And what is that value you are setting it to?
Message 11 of 17
(2,122 Views)
I tried 5, 10, 50. All integer value
Message 12 of 17
(2,121 Views)
Accepted by topic author Ivv
And did you run highlight execution?
If you have value=5, The first comparison in that loop is i<= value.   Since it is the first iteration, i =0.   So i <= value becomes 0<= 5.   TRUE!   True goes to the OR then the stop conditional terminal.  Loop is done after that first iteration.
Perhaps you wanted >=  ??
Message 13 of 17
(2,113 Views)
Perhaps you want an integer and not a float.  Make the terminal and wire blue.
Message 14 of 17
(2,107 Views)
@Ivv wrote:
I have a problem with this i, i's value isn't passed to the Tank variable and block this Loop work.
Can you help me?
I would like changing my work from this
To this modul
OK, instead of attaching gibberish code, take a step back and tell us what the program is supposed to do. I doubt any of your local variables are needed. There is nothing to "fix", because this needs to be rewritten from scratch with proper dataflow in mind. Won't be hard!
So, answer one question:
If the program is running, what is the user supposed to see and how should the program react if the user does nothing or changes each of the controls?
Simple as that! 😄
Message 15 of 17
(2,101 Views)
ok ... I'm a donkey. Thanks so much
Message 16 of 17
(2,087 Views)
(Such a cute translation.)
No, you are NOT an @$$.  Everyone does this kind of stuff because we're all human.
Bill
CLD
(Mid-Level minion.)
Message 17 of 17
(2,083 Views)
