Loop Condition not working
I have been having some trouble in exiting a loop in a program I am working on, and suspected that, for some reason, the loop stop button is not really doing anything, so I decided to do a sanity test and create a whole blank program with an empty vi that has nothing but a loop and a stop button to stop it. The loop never stops, and the program never exits. This has been really driving me crazy, as no forum post seems to have ever mentioned such a problem, and I have written programs in LabVIEW many times before. Now, even when I open these old programs, at least the ones that do have a stop button in a while loop, they too have mysteriously stopped working out of a sudden. Am I going crazy and really just missing a stupid little thing, or is this some kind of more complicated problem with LabVIEW? The stop condition is set to stop when True and the button type or latching type has not changed anything, not that it even should anyway, as it should stop when true, no matter what. I tried restarting the PC and labview. I even changed the boolean to a constant that is always either true or false and nothing changed still.
Message 1 of 11
(2,623 Views)
-deleted-
Certified LabVIEW Architect
Message 2 of 11
(2,605 Views)
No one will be able to help you unless you attach the .vi.
Message 3 of 11
(2,557 Views)
Are you inadvertently pressing Run Continously instead of the standard Run button?
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 4 of 11
(2,551 Views)
do you have the button outside the loop so the value is always constant inside the loop?
Qestit Systems
Certified-LabVIEW-Developer
Message 5 of 11
(2,540 Views)
posted verbatim and answered on reddit already.
Picture there was included and the problem was the "continuous run".
Message 6 of 11
(2,527 Views)
As a reminder, there is still this idea comment stating that the "continuous run" button should only be shown on the diagram window, not on front panel window.
Message 7 of 11
(2,505 Views)
And everytime someone clicks it you should get a pop-up with "Are you sure" and a second one "Are you really sure?" before starting. 🙂
Qestit Systems
Message 8 of 11
(2,445 Views)
I just accidentally clicked on Stop instead of Pause. The consequences when debugging sometimes...
I wish Ctrl+. would work when the Stop button is disabled.
Message 9 of 11
(2,439 Views)
Where ctrl+. doesn't work, this usually does.
Jim
Message 10 of 11
(2,403 Views)
