Loop Rates not adhered to while Emulating FPGA vi
I have two single cycle timed loops, one running at 50MHz and the other running at 100MHz.
When I emulate, I don't expect the loops to run at the requested rates, but I'd expect the 100MHz loop to run roughly twice as fast as the 50MHz loop.
Actually I see the 50MHz loop running faster?
Is this expected behavior?
(2,611 Views)
The emulator is only for testing of the semantics, not of the timing behaviour.
Christian
(2,602 Views)
